Fast numeric to string conversions.
More...
#include <stddef.h>
#include "epicsTypes.h"
#include "libComAPI.h"
#define | cvtCharToString(val, str) cvtInt32ToString(val, str) |
#define | cvtUcharToString(val, str) cvtUInt32ToString(val, str) |
#define | cvtShortToString(val, str) cvtInt32ToString(val, str) |
#define | cvtUshortToString(val, str) cvtUInt32ToString(val, str) |
#define | cvtLongToString(val, str) cvtInt32ToString(val, str) |
#define | cvtUlongToString(val, str) cvtUInt32ToString(val, str) |
#define | cvtLongToHexString(val, str) cvtInt32ToHexString(val, str) |
#define | cvtULongToHexString(val, str) cvtUInt32ToHexString(val, str) |
#define | cvtLongToOctalString(val, str) cvtInt32ToOctalString(val, str) |
LIBCOM_API int | cvtFloatToString (float val, char *pdest, epicsUInt16 prec) |
LIBCOM_API int | cvtDoubleToString (double val, char *pdest, epicsUInt16 prec) |
LIBCOM_API int | cvtFloatToExpString (float val, char *pdest, epicsUInt16 prec) |
LIBCOM_API int | cvtDoubleToExpString (double val, char *pdest, epicsUInt16 prec) |
LIBCOM_API int | cvtFloatToCompactString (float val, char *pdest, epicsUInt16 prec) |
LIBCOM_API int | cvtDoubleToCompactString (double val, char *pdest, epicsUInt16 prec) |
LIBCOM_API size_t | cvtInt32ToString (epicsInt32 val, char *pdest) |
LIBCOM_API size_t | cvtUInt32ToString (epicsUInt32 val, char *pdest) |
LIBCOM_API size_t | cvtInt64ToString (epicsInt64 val, char *pdest) |
LIBCOM_API size_t | cvtUInt64ToString (epicsUInt64 val, char *pdest) |
LIBCOM_API size_t | cvtInt32ToHexString (epicsInt32 val, char *pdest) |
LIBCOM_API size_t | cvtUInt32ToHexString (epicsUInt32 val, char *pdest) |
LIBCOM_API size_t | cvtInt32ToOctalString (epicsInt32 val, char *pdest) |
LIBCOM_API size_t | cvtInt64ToHexString (epicsInt64 val, char *pdest) |
LIBCOM_API size_t | cvtUInt64ToHexString (epicsUInt64 val, char *pdest) |
- Author
- Bob Dalesio, Mark Anderson, Marty Kraimer
Provides routines for converting various numeric types into an ascii string. They off a combination of speed and convenience not available with sprintf().
All functions return the number of characters in the output
Definition in file cvtFast.h.
