EPICS Base
7.0.6.1
Public Attributes | |
| void(* | priv_free )(void *puser) |
| parse_result(* | parse_start )(chFilter *filter) |
| void(* | parse_abort )(chFilter *filter) |
| parse_result(* | parse_end )(chFilter *filter) |
| parse_result(* | parse_null )(chFilter *filter) |
| parse_result(* | parse_boolean )(chFilter *filter, int boolVal) |
| parse_result(* | parse_integer )(chFilter *filter, long integerVal) |
| parse_result(* | parse_double )(chFilter *filter, double doubleVal) |
| parse_result(* | parse_string )(chFilter *filter, const char *stringVal, size_t stringLen) |
| parse_result(* | parse_start_map )(chFilter *filter) |
| parse_result(* | parse_map_key )(chFilter *filter, const char *key, size_t stringLen) |
| parse_result(* | parse_end_map )(chFilter *filter) |
| parse_result(* | parse_start_array )(chFilter *filter) |
| parse_result(* | parse_end_array )(chFilter *filter) |
| long(* | channel_open )(chFilter *filter) |
| void(* | channel_register_pre )(chFilter *filter, chPostEventFunc **cb_out, void **arg_out, db_field_log *probe) |
| void(* | channel_register_post )(chFilter *filter, chPostEventFunc **cb_out, void **arg_out, db_field_log *probe) |
| void(* | channel_report )(chFilter *filter, int level, const unsigned short indent) |
| void(* | channel_close )(chFilter *filter) |
Definition at line 83 of file dbChannel.h.
1.8.5
