10 #define INC_testMain_H
31 #if defined(__rtems__)
33 #define MAIN(prog) extern "C" int prog(void); extern "C" int main() __attribute__((weak, alias(#prog))); extern "C" int prog(void)
35 #define MAIN(prog) int prog(); int main() __attribute__((weak, alias(#prog))); int prog()
37 #elif defined(vxWorks)
39 #define MAIN(prog) extern "C" int prog(void)
41 #define MAIN(prog) int prog()
45 #define MAIN(prog) int main(int , char * [] )
47 #define MAIN(prog) int main(int argc, char *argv[] )
