EPICS Base
7.0.7.0
Main Page
Related Pages
Modules
Classes
Files
File List
File Members
All
Classes
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Macros
Groups
Pages
devLib.h
1
2
* Copyright (c) 2010 Brookhaven Science Associates, as Operator of
3
* Brookhaven National Laboratory.
4
* Copyright (c) 2008 UChicago Argonne LLC, as Operator of Argonne
5
* National Laboratory.
6
* Copyright (c) 2002 The Regents of the University of California, as
7
* Operator of Los Alamos National Laboratory.
8
* SPDX-License-Identifier: EPICS
9
* EPICS BASE is distributed subject to a Software License Agreement found
10
* in file LICENSE that is included with this distribution.
11
12
20
#ifndef EPICSDEVLIB_H
21
#define EPICSDEVLIB_H
22
29
#define devCreateMask(NBITS) ((1<<(NBITS))-1)
30
31
#define devDigToNml(DIGITAL,NBITS) \
32
(((double)(DIGITAL))/devCreateMask(NBITS))
33
34
#define devNmlToDig(NORMAL,NBITS) \
35
(((long)(NORMAL)) * devCreateMask(NBITS))
36
44
#define devCreateAlignmentMask(CTYPE)\
45
(sizeof(CTYPE)>sizeof(double)?sizeof(double)-1:sizeof(CTYPE)-1)
46
50
#define devPtrAlignTest(PTR) (!(devCreateAlignmentMask(*PTR)&(long)(PTR)))
51
57
#define S_dev_success 0
58
59
#define S_dev_vectorInUse (M_devLib| 1)
/*Interrupt vector in use*/
60
61
#define S_dev_vecInstlFail (M_devLib| 2)
/*Interrupt vector install failed*/
62
63
#define S_dev_uknIntType (M_devLib| 3)
/*Unrecognized interrupt type*/
64
65
#define S_dev_vectorNotInUse (M_devLib| 4)
/*Interrupt vector not in use by caller*/
66
67
#define S_dev_badA16 (M_devLib| 5)
/*Invalid VME A16 address*/
68
69
#define S_dev_badA24 (M_devLib| 6)
/*Invalid VME A24 address*/
70
71
#define S_dev_badA32 (M_devLib| 7)
/*Invalid VME A32 address*/
72
73
#define S_dev_uknAddrType (M_devLib| 8)
/*Unrecognized address space type*/
74
75
#define S_dev_addressOverlap (M_devLib| 9)
/*Specified device address overlaps another device*/
76
77
#define S_dev_identifyOverlap (M_devLib| 10)
/*This device already owns the address range*/
78
79
#define S_dev_addrMapFail (M_devLib| 11)
/*Unable to map address*/
80
81
#define S_dev_intDisconnect (M_devLib| 12)
/*Interrupt at vector disconnected from an EPICS device*/
82
83
#define S_dev_internal (M_devLib| 13)
/*Internal failure*/
84
85
#define S_dev_intEnFail (M_devLib| 14)
/*Unable to enable interrupt level*/
86
87
#define S_dev_intDissFail (M_devLib| 15)
/*Unable to disable interrupt level*/
88
89
#define S_dev_noMemory (M_devLib| 16)
/*Memory allocation failed*/
90
91
#define S_dev_addressNotFound (M_devLib| 17)
/*Specified device address unregistered*/
92
93
#define S_dev_noDevice (M_devLib| 18)
/*No device at specified address*/
94
95
#define S_dev_wrongDevice (M_devLib| 19)
/*Wrong device type found at specified address*/
96
97
#define S_dev_badSignalNumber (M_devLib| 20)
/*Signal number (offset) to large*/
98
99
#define S_dev_badSignalCount (M_devLib| 21)
/*Signal count to large*/
100
101
#define S_dev_badRequest (M_devLib| 22)
/*Device does not support requested operation*/
102
103
#define S_dev_highValue (M_devLib| 23)
/*Parameter too high*/
104
105
#define S_dev_lowValue (M_devLib| 24)
/*Parameter too low*/
106
107
#define S_dev_multDevice (M_devLib| 25)
/*Specified address is ambiguous (more than one device responds)*/
108
109
#define S_dev_badSelfTest (M_devLib| 26)
/*Device self test failed*/
110
111
#define S_dev_badInit (M_devLib| 27)
/*Device failed during initialization*/
112
113
#define S_dev_hdwLimit (M_devLib| 28)
/*Input exceeds Hardware Limit*/
114
115
#define S_dev_deviceDoesNotFit (M_devLib| 29)
/*Unable to locate address space for device*/
116
117
#define S_dev_deviceTMO (M_devLib| 30)
/*Device timed out*/
118
119
#define S_dev_badFunction (M_devLib| 31)
/*Bad function pointer*/
120
121
#define S_dev_badVector (M_devLib| 32)
/*Bad interrupt vector*/
122
123
#define S_dev_badArgument (M_devLib| 33)
/*Bad function argument*/
124
125
#define S_dev_badISA (M_devLib| 34)
/*Invalid ISA address*/
126
127
#define S_dev_badCRCSR (M_devLib| 35)
/*Invalid VME CR/CSR address*/
128
129
#define S_dev_vxWorksIntEnFail S_dev_intEnFail
130
132
#endif
/* EPICSDEVLIB_H */
133
134
135
* Retain compatibility by including VME by default
136
137
#ifndef NO_DEVLIB_COMPAT
138
# include "
devLibVME.h
139
#endif
devLibVME.h
API for accessing hardware devices, mosty over VMEbus.
Generated on Wed Sep 7 2022 16:32:57 for EPICS Base by
1.8.5
