10 #define INC_testMain_H
42 #if defined(__rtems__)
44 #define MAIN(prog) extern "C" int prog(void); extern "C" int main() __attribute__((weak, alias(#prog))); extern "C" int prog(void)
46 #define MAIN(prog) int prog(); int main() __attribute__((weak, alias(#prog))); int prog()
48 #elif defined(vxWorks)
50 #define MAIN(prog) extern "C" int prog(void)
52 #define MAIN(prog) int prog()
56 #define MAIN(prog) int main(int , char * [] )
58 #define MAIN(prog) int main(int argc, char *argv[] )
