1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: ADPICam: epicsMutexOsdUnlock failed: ERROR Operation not permitted
From: Jörn Dreyer via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Cc: Fernando Ardana <[email protected]>
Date: Thu, 15 Feb 2024 09:40:48 +0100
Hi Mark,
as I mentioned before, I had the same error from a driver I wrote for another type of cameras.
I traced this down into the handleNewImageTask function. In the beginning of the while loop (line 4913 and 4914 in ADPicam.cpp) there are two unlock calls. If I comment those out, the error vanishes. These two calls should be moved towards the end of the while loop.
Jörn
Am Mittwoch, 14. Februar 2024, 21:36:01 CET schrieb Mark Rivers via Tech-talk:
> I recommend that you open this as an issue in ADPICAM.  Please include the following:
>   *   A screenshot of the top-level ADPICAM screen.
>   *   The complete output when the IOC starts up.
> Mark
> From: Tech-talk <[email protected]> On Behalf Of Fernando Ardana via Tech-talk
> Sent: Wednesday, February 14, 2024 4:06 AM
> To: [email protected]
> Subject: ADPICam: epicsMutexOsdUnlock failed: ERROR Operation not permitted
> Hi all,
> I am having some problems with the ADPICAM module. I can connect and acquire images using the sample software provide it by Princeton. In Epics the camera is detected however cannot connect to it. After running by ioc I get:
> PICamConfig("PICAM", 0, 0, 0, 0)
> epicsMutex pthread_mutex_unlock epicsMutexOsdUnlock failed: ERROR Operation not permitted
> Running asynReport(20) I can see the camera:
> PICam:report Initialized PICam Version 5.13.3.2211
> PICam:report availableCamerasCount 1
> Available Camera[0]
> ---PIXIS-XO: 2KB
> ---1
> ---E2V 2048 x 512 (CCD 42-10)(B)
> ---2702080007
> Any idea of what is wrong?
> Best and thanks,
> Fernando
ADPICam: epicsMutexOsdUnlock failed: ERROR Operation not permitted Fernando Ardana via Tech-talk
RE: ADPICam: epicsMutexOsdUnlock failed: ERROR Operation not permitted Mark Rivers via Tech-talk
Prev: RE: ADPICam: epicsMutexOsdUnlock failed: ERROR Operation not permitted Mark Rivers via Tech-talk
Next: EPICS DB Record does not update with periodic SCAN Adrian Martinez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
