On 1/10/26 7:02 AM, Torsten
Bögershausen via Tech-talk wrote:
Hej
Experts,
after problems with C++ code I needed to re-install the
xcode command line tools here.
However, trying to compile a motor driver didn't work very well:
../smarActMCS2MotorDriver.cpp:151:10:
error: integer value 10 is outside the valid range of
values [0, 7] for the enumeration type 'asynStatus'
[-Wenum-constexpr-conversion]
151 | case asynParamUndefined:
c++ --version
Apple clang version 17.0.0 (clang-1700.6.3.2)
Are there any better suggestions ?
Could you open an issue for asyn?
It looks like some cleverness in asyn now conflicts with some
cleverness in clang.
- Re: Problems with clang under MacOS Torsten Bögershausen via Tech-talk
- Problems with clang under MacOS Torsten Bögershausen via Tech-talk
Re: Configuration of the RGA200 communication baud rate Johnson, Andrew N. via Tech-talk
Re: Configuration of the RGA200 communication baud rate Michael Davidsaver via Tech-talk
2025
<2026>
2025
<2026>
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
