/[TIS-4000 Rel T60]/Tornado/Cb/Makefile.config
Log of /Tornado/Cb/Makefile.config
Fri Dec 10 14:28:05 1999 UTC (24 years ago) by tis4000
Changes since 1.1: +2 -14 lines
Deleted all defines except M30INX and X486INX to allow include of special
directores
Steel
Mon Nov 1 16:38:13 1999 UTC (24 years, 1 month ago) by tis4000
CVS Tags: t55baseline
ComputerBoards Inc driver - palmer
Powered by ViewVC 1.1.30
