/[TIS-4000 Rel T60]/Tornado/Csi/Makefile.config
Log of /Tornado/Csi/Makefile.config
Fri Dec 10 14:32:41 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.2: +2 -14 lines
Deleted all  defines except M30INX and X486INX to allow include of special directories.
Steel
Fri Sep 17 13:17:37 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline
Remove Id line - irani
Mon Aug 23 18:43:17 1999 UTC (24 years, 6 months ago) by tis4000
Branch: HIA
CVS Tags: T60
initial version
Branch point for: HIA
Powered by ViewVC 1.1.30
