/[TIS-4000 Rel T60]/Tornado/Enraf/Makefile
Annotation of /Tornado/Enraf/Makefile
Revision 1.1.1.1 - (hide annotations) (vendor branch)
Branch: HIA, MAIN
CVS Tags: CAISO, t55baseline, T60, Duluth_baseline, LMC_baseline, HEAD
initial version
1 tis4000 1.1 #$Id: Makefile,v 1.1.1.1 1999/08/23 13:34:38 tis4000 Exp $
2
3     #
4     # this Makefile is basically a stub to ensure the auto-regeneration
5     # of the target-specific makefiles and their subsequent execution; it
6     # checks the dependencies of the component Makefile.* files just in
7     # case something changes ...
8     #
9
10     include Makefile.config
11
12     #
13     # tl is a small 'C' program to get the tail of the current
14     # directory and stuff it into CUR
15     #
16
17     CUR:sh = ../makeutils/tl `eval pwd`
18
19     #
20     # this is a 'null' target to force the execution of our Makefiles
21     #
22
23     default:: M30 X486
24
25     M30 :
26     mkdir M30
27     X486 :
28     mkdir X486
29
30     default::
31     @ for sd in * ; do \
32     if test -d $$sd ; then \
33     ( cd $$sd ; \
34     echo "" ; \
35     echo "checking $(CUR)/$$sd Makefile ..." ; \
36     if test $$sd = M00 ; then set 68000 soft-float msol 68k 68K MC68000; \
37     elif test $$sd = M30 ; then set 68030 68881 mv147 68k 68K MC68030; \
38     elif test $$sd = X486 ; then set 486 "" pc386 386 386 I80486; \
39     else \
40     if test $$sd != CVS ; then echo "$$sd is not a target directory" ; fi ; \
41     continue ; \
42     fi ; \
43     make -f ../../Makefile.defaults CPU=$$1 FLT=$$2 BSP=$$3 DST=$$sd CUR=$(CUR) TARG=$$4 GCC_BASE=$$5 CPU_FAM=$$6 Makefile.$$sd ; \
44     echo "building $(CUR)/$$sd targets ..." ; \
45     make -f Makefile.$$sd \
46     ) ; \
47     fi ; \
48     done
49
50     #
51     # utility targets
52     #
53
54     clean:
55     @ for sd in * ; do \
56     if test -d $$sd ; then \
57     if test $$sd = M00 -o $$sd = M30 -o $$sd = X486; then \
58     echo "removing "`eval pwd`"/$$sd targets ..." ; $(RM) $$sd/* ; \
59     else \
60     if test $$sd != CVS ; then echo "$$sd is not a target directory" ; fi ; \
61     continue ; \
62     fi ; \
63     fi ; \
64     done
Powered by ViewVC 1.1.30
