/[TIS-4000 Rel T60]/Tornado/FileTransfer/Makefile.target |
Parent Directory
Revision Log
Revision Graph
Sticky Tag: |
Placed special targets that are X486 or privilege dependent in the target defined by the CPU = I80486. Steel
Filetransfer utilities, secure and standard - bekkerman
ViewVC Help | |
Powered by ViewVC 1.1.30 |
