/[TIS-4000 Rel T60]/Tornado/FileTransfer/Makefile.target
Log of /Tornado/FileTransfer/Makefile.target
Links to LMC_baseline: (view) (annotate)
Fri Dec 10 15:00:39 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.1: +4 -1 lines
Placed special targets that are X486 or privilege dependent in the target defined
by the CPU = I80486.
Steel
Fri Sep 17 14:54:04 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline
Filetransfer utilities, secure and standard - bekkerman
Powered by ViewVC 1.1.30
