/[TIS-4000 Rel T60]/Tornado/Hyundai/Makefile.config
Log of /Tornado/Hyundai/Makefile.config
Fri Sep 17 13:17:38 1999 UTC (24 years, 2 months ago) by tis4000
Remove Id line - irani
Mon Aug 23 18:43:18 1999 UTC (24 years, 3 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Diff to previous 1.1 , to next main 1.2
initial version
Branch point for: HIA
Powered by ViewVC 1.1.30
