/[TIS-4000 Rel T60]/Tornado/Iccp/Makefile.config
Contents of /Tornado/Iccp/Makefile.config
Revision 1.2 - (show annotations)
Fri Sep 17 13:17:45 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline
Remove Id line - irani
1 #
2 # Makefile.config
3 # !! special 'driver' version = Makefile.drvcnfg
4 #
5 # this file contains specific configuration for a given directory '.../Vx/xxx'
6 # by defining the working directory name, any special include search path
7 # directories, the source file list (used for make 'depend'), and the object
8 # module list (used by default user target).
9 #
10
11 #
12 # extra switches for each machine flavor
13 #
14
15 M00INX = -I$(TISH)\rec
16 M00CCX = -DvxWorks -DV5_vxWorks
17 M00OPT =
18
19 M20INX = -I$(TISH)\rec
20 M20CCX = -DvxWorks -DV5_vxWorks
21 M20OPT =
22
23 M30INX = -I$(TISH)\rec
24 M30CCX = -DvxWorks -DV5_vxWorks
25 M30OPT =
26
27 X486INX = -I$(TISH)\rec
28 X486CCX = -DvxWorks -DV5_vxWorks
29 X486OPT =
30
31 #
32 # Define the source list for $(CUR).o
33 # $(SRC)\dev$(CUR).c \
34 # $(SRC)\drv$(CUR).c \
35
36
37 SRCS =\
38 $(SRC)\access.c \
39 $(SRC)\casm.c \
40 $(SRC)\cfg1006.c \
41 $(SRC)\emitfetc.c \
42 $(SRC)\error.c \
43 $(SRC)\files.c \
44 $(SRC)\iccpdata.c \
45 $(SRC)\iccpio.c \
46 $(SRC)\iccptask.c \
47 $(SRC)\ioroutin.c \
48 $(SRC)\mmsdecod.c \
49 $(SRC)\mmstypes.c \
50 $(SRC)\pr_tab.c \
51 $(SRC)\rfc1006.c \
52 $(SRC)\search.c \
53 $(SRC)\service.c \
54 $(SRC)\tam.c \
55 $(SRC)\tam_tp.c \
56 $(SRC)\utility.c \
57 $(SRC)\vxiccp.c \
58 $(SRC)\win_time.c \
59 $(SRC)\yy_tab.c \
60 # ---
61
62 #
63 # Define the object list for $(CUR).o
64 # dev$(CUR).o \
65 # drv$(CUR).o \
66
67 OBJS =\
68 access.o \
69 casm.o \
70 cfg1006.o \
71 emitfetc.o \
72 error.o \
73 files.o \
74 iccpdata.o \
75 iccpio.o \
76 iccptask.o \
77 ioroutin.o \
78 mmsdecod.o \
79 mmstypes.o \
80 pr_tab.o \
81 rfc1006.o \
82 search.o \
83 service.o \
84 tam.o \
85 tam_tp.o \
86 utility.o \
87 vxiccp.o \
88 win_time.o \
89 yy_tab.o \
90 # ---
91
92 #
93 # END of Makefile.config
94 #
Powered by ViewVC 1.1.30
