/[TIS-4000 Rel T60]/Tornado/Makefile
Log of /Tornado/Makefile
Revision 1.9 - (view) (annotate) - [select for diffs]
Fri Mar 31 15:11:37 2000 UTC (23 years, 8 months ago) by tis4000
comment out Eim driver, not ready to be built yet - Steel
Revision 1.8 - (view) (annotate) - [select for diffs]
Fri Mar 31 14:42:05 2000 UTC (23 years, 8 months ago) by tis4000
Changes since 1.7: +72 -92 lines
Deleted obsolete drivers, added new drivers, commented out those drivers not currently being built, reordered the driver list so that it is alphabetical. - Palmer
Revision 1.7 - (view) (annotate) - [select for diffs]
Wed Mar 22 16:40:56 2000 UTC (23 years, 8 months ago) by tis4000
Changes since 1.6: +2 -2 lines
Change dnp to Dnp, and iccp to Iccp - Steel
Revision 1.6 - (view) (annotate) - [select for diffs]
Mon Dec 6 21:07:40 1999 UTC (24 years ago) by tis4000
Disable the building of iocTrend which is not ready for prime time. - Steel
Revision 1.5 - (view) (annotate) - [select for diffs]
Wed Nov 10 19:10:06 1999 UTC (24 years ago) by tis4000
CVS Tags: SPR393
SPR 393
Included iocTrend target for Tornado. - Steel
Mon Nov 1 19:46:11 1999 UTC (24 years, 1 month ago) by tis4000
CVS Tags: t55baseline
Add Cb driver to build targets - irani
Mon Nov 1 19:01:53 1999 UTC (24 years, 1 month ago) by tis4000
Add Sabplc to build targets - irani
Fri Sep 17 11:13:15 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: CAISO
Changes since 1.1: +7 -1 lines
Add diagtools, digi, and filetransfer; add ModiconSlv - irani
Mon Aug 23 18:43:16 1999 UTC (24 years, 3 months ago) by tis4000
Branch point for: HIA
Diff to selected 1.2
Powered by ViewVC 1.1.30
