/[TIS-4000 Rel T60]/Tornado/Makefile
Log of /Tornado/Makefile
Links to SPR393: (view) (annotate)
Revision 1.5 - (view) (annotate) - [select for diffs]
Wed Nov 10 19:10:06 1999 UTC (24 years, 1 month ago) by tis4000
CVS Tags: SPR393
SPR 393
Included iocTrend target for Tornado. - Steel
Mon Nov 1 19:46:11 1999 UTC (24 years, 1 month ago) by tis4000
CVS Tags: t55baseline
Add Cb driver to build targets - irani
Mon Nov 1 19:01:53 1999 UTC (24 years, 1 month ago) by tis4000
Add Sabplc to build targets - irani
Fri Sep 17 11:13:15 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: CAISO
Changes since 1.1: +7 -1 lines
Add diagtools, digi, and filetransfer; add ModiconSlv - irani
Mon Aug 23 18:43:16 1999 UTC (24 years, 3 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
