/[TIS-4000 Rel T60]/Tornado/Mapbd/Makefile.target
Annotation of /Tornado/Mapbd/Makefile.target
Revision 1.3 - (hide annotations)
Fri Dec 10 15:11:06 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: Duluth_baseline, LMC_baseline, HEAD
Added -r switch to LD command - Steel
1 tis4000 1.1 #
2     # Makefile.target
3     # !! special 'driver' version = Makefile.drvtarg
4     #
5     # this file defines the default target and its components
6     # for the current build directory; there must be a target
7     # named 'user_target' (see Makefile.defaults) somewhere at
8     # the head of the chain, otherwise there aren't really any
9     # constraints ...
10     #
11
12     user_target: $(CUR).o
13
14     #
15     # Define targets for the $(CUR).o
16     #
17
18     $(CUR).o: $(OBJS)
19     @ echo "linking $(CUR).o for $(DST)"
20     @ $(RM) $@
21 tis4000 1.3 @ $(LD) -r $(OBJS) -o $@
22 tis4000 1.1
23     #
24     # END of Makefile.target
25     #
26     # Dependency list for .o files - automatically generated!!
27     # reference ./Makefile & ../Makefile.defaults
28     #
29
Powered by ViewVC 1.1.30
