/[TIS-4000 Rel T60]/Tornado/Modicon/Makefile
Diff of /Tornado/Modicon/Makefile
Parent Directory Parent Directory | Revision Log Revision Log | View Revision Graph Revision Graph | View Patch Patch
revision 1.3 by tis4000, Mon Nov 1 16:11:07 1999 UTC revision 1.4 by tis4000, Mon Nov 1 16:15:48 1999 UTC
# Line 1  Line 1
1  # Define the local target base directory  # Define the local target base directory
2  CUR = Cb  CUR = Modicon
3
4  # Define the release root directory  # Define the release root directory
5  TOP = ../../..  TOP = ../../..
# Line 13  MAKE_TOP = $(TOP)\tornado\stdMakefiles Line 13  MAKE_TOP = $(TOP)\tornado\stdMakefiles
13
14  # TORNADO Makefile strategy-  # TORNADO Makefile strategy-
15  #   perform make with the -C <dir> for each valid target  #   perform make with the -C <dir> for each valid target
16  #       Each target subdir will select correct Make include environment  #       Each target subdir will select correct Make include environment
17  #       target names hardcoded for now  #       target names hardcoded for now
18
19  default:: M30 X486  default:: M30 X486
20
Legend:
Removed from v.1.3
changed lines
  Added in v.1.4
Powered by ViewVC 1.1.30
