/[TIS-4000 Rel T60]/Tornado/Q984/Makefile.target
Log of /Tornado/Q984/Makefile.target
Revision 1.6 - (view) (annotate) - [select for diffs]
Fri Mar 31 15:55:08 2000 UTC (23 years, 11 months ago) by tis4000
Change / to \  for copy command - Steel
Revision 1.5 - (view) (annotate) - [select for diffs]
Wed Feb 9 15:40:01 2000 UTC (24 years ago) by tis4000
change cp -p to copy, sice cp not understood on NT - Steel
Wed Feb 9 15:29:39 2000 UTC (24 years ago) by tis4000
Changes since 1.3: +4 -1 lines
Copy the qriom.bin file from the src/Q984 directory to the make directory. - Steel
Fri Dec 10 15:32:09 1999 UTC (24 years, 2 months ago) by tis4000
Added -r switch to LD command - Steel
Fri Sep 17 13:17:39 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline
Remove Id line - irani
Mon Aug 23 18:43:19 1999 UTC (24 years, 6 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Diff to previous 1.1 , to next main 1.6
initial version
Branch point for: HIA
Powered by ViewVC 1.1.30
