/[TIS-4000 Rel T60]/Tornado/Rtp/Makefile.target
Contents of /Tornado/Rtp/Makefile.target
Revision 1.3 - (show annotations)
Fri Dec 10 15:46:34 1999 UTC (24 years ago) by tis4000
CVS Tags: Duluth_baseline, LMC_baseline, HEAD
Added -r switch to LD command - Steel
1 #
2 # Makefile.target
3 # !! special 'driver' version = Makefile.drvtarg
4 #
5 # this file defines the default target and its components
6 # for the current build directory; there must be a target
7 # named 'user_target' (see Makefile.defaults) somewhere at
8 # the head of the chain, otherwise there aren't really any
9 # constraints ...
10 #
11
12 user_target: $(CUR).o
13
14 #
15 # Define targets for the $(CUR).o
16 #
17
18 $(CUR).o: $(OBJS)
19 @ echo "linking $(CUR).o for $(DST)"
20 @ $(RM) $@
21 @ $(LD) -r $(OBJS) -o $@
22
23 #
24 # END of Makefile.target
25 #
26 # Dependency list for .o files - automatically generated!!
27 # reference ./Makefile & ../Makefile.defaults
28 #
29
Powered by ViewVC 1.1.30
