/[TIS-4000 Rel T60]/Tornado/bin/Makefile.config
Log of /Tornado/bin/Makefile.config
Fri Dec 10 14:06:18 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.2: +0 -12 lines
Placed all special priv targets under the user target defiend by the
CPU = I80486
Steel
Fri Sep 17 11:18:04 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline
Changes since 1.1: +0 -1 lines
Remove $Id line - irani
Revision 1.1 - (view) (annotate) - [selected]
Mon Aug 23 18:43:17 1999 UTC (24 years, 6 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
