/[TIS-4000 Rel T60]/Tornado/boot_tools/Makefile.config
Log of /Tornado/boot_tools/Makefile.config
Fri Dec 10 14:10:02 1999 UTC (23 years, 11 months ago) by tis4000
Changes since 1.2: +2 -14 lines
Deleted all defines except M30INX and X486INX to allow include od special
Directories.
Steel
Fri Sep 17 13:17:44 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: CAISO, t55baseline
Changes since 1.1: +0 -1 lines
Remove Id line - irani
Mon Aug 23 18:43:17 1999 UTC (24 years, 3 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
