/[TIS-4000 Rel T60]/Tornado/ca/Makefile.target
Annotation of /Tornado/ca/Makefile.target
Revision 1.3 - (hide annotations)
Fri Dec 10 14:20:57 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: Duluth_baseline, LMC_baseline, HEAD
Changes since 1.2: +4 -1 lines
Placed special targets that are X486 or privilege dependent in the target defined by the CPU = I80486
Steel
1 tis4000 1.1
2     #
3     # Makefile.target
4     #
5     # this file defines the default target and its components
6     # for the current build directory; there must be a target
7     # named 'user_target' (see Makefile.defaults) somewhere at
8     # the head of the chain, otherwise there aren't really any
9     # constraints ...
10     #
11 tis4000 1.3 ifeq ($(CPU),I80486)
12 tis4000 1.1 user_target: depend caLib.o priv_caLib.o
13 tis4000 1.3 else
14     user_target: depend caLib.o
15     endif
16 tis4000 1.1
17     #
18     # Define targets for the caLib.o
19     #
20
21     caLib.o: $(OBJS)
22     @ echo "linking caLib.o for $(DST)"
23     @ $(RM) $@
24     @ $(LD) -r $(OBJS) -o $@
25
26     priv_caLib.o: $(PRIV_OBJS)
27     @ echo "linking priv_caLib.o for $(DST)"
28     @ $(RM) $@
29     @ $(LD) -r $(PRIV_OBJS) -o $@
30
31     # note: by making the special version dependent on the
32     # standard, we inherit the dependencies.
33     priv_sockMnt.o: sockMnt.o
34     @ $(RM) priv_sockMnt.o
35     $(CC) -DvxWorks -DV5_vxWorks -c $(CFLAGS) -DPRIV_AUDIT -o $@ $(SRC)/sockMnt.c
36
37     priv_chanAcq.o: chanAcq.o
38     @ $(RM) priv_chanAcq.o
39     $(CC) -DvxWorks -DV5_vxWorks -c $(CFLAGS) -DPRIV_AUDIT -o $@ $(SRC)/chanAcq.c
40
41     #
42     # END of Makefile.target
43     #
44     # Dependency list for .o files - automatically generated!!
45     # reference ./Makefile & ../Makefile.defaults
46     #
47
Powered by ViewVC 1.1.30
