/[TIS-4000 Rel T60]/Tornado/ca/Makefile.target
Contents of /Tornado/ca/Makefile.target
Revision 1.3 - (show annotations)
Fri Dec 10 14:20:57 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: Duluth_baseline, LMC_baseline, HEAD
Changes since 1.2: +4 -1 lines
Placed special targets that are X486 or privilege dependent in the target defined by the CPU = I80486
Steel
1
2 #
3 # Makefile.target
4 #
5 # this file defines the default target and its components
6 # for the current build directory; there must be a target
7 # named 'user_target' (see Makefile.defaults) somewhere at
8 # the head of the chain, otherwise there aren't really any
9 # constraints ...
10 #
11 ifeq ($(CPU),I80486)
12 user_target: depend caLib.o priv_caLib.o
13 else
14 user_target: depend caLib.o
15 endif
16
17 #
18 # Define targets for the caLib.o
19 #
20
21 caLib.o: $(OBJS)
22 @ echo "linking caLib.o for $(DST)"
23 @ $(RM) $@
24 @ $(LD) -r $(OBJS) -o $@
25
26 priv_caLib.o: $(PRIV_OBJS)
27 @ echo "linking priv_caLib.o for $(DST)"
28 @ $(RM) $@
29 @ $(LD) -r $(PRIV_OBJS) -o $@
30
31 # note: by making the special version dependent on the
32 # standard, we inherit the dependencies.
33 priv_sockMnt.o: sockMnt.o
34 @ $(RM) priv_sockMnt.o
35 $(CC) -DvxWorks -DV5_vxWorks -c $(CFLAGS) -DPRIV_AUDIT -o $@ $(SRC)/sockMnt.c
36
37 priv_chanAcq.o: chanAcq.o
38 @ $(RM) priv_chanAcq.o
39 $(CC) -DvxWorks -DV5_vxWorks -c $(CFLAGS) -DPRIV_AUDIT -o $@ $(SRC)/chanAcq.c
40
41 #
42 # END of Makefile.target
43 #
44 # Dependency list for .o files - automatically generated!!
45 # reference ./Makefile & ../Makefile.defaults
46 #
47
Powered by ViewVC 1.1.30
