/[TIS-4000 Rel T60]/Tornado/ca/Makefile
Annotation of /Tornado/ca/Makefile
Revision 1.2 - (hide annotations)
Fri Sep 17 13:17:44 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline, Duluth_baseline, LMC_baseline, HEAD
Changes since 1.1: +0 -1 lines
Remove Id line - irani
1 tis4000 1.1
2     # Define the local target base directory
3     CUR = ca
4
5     # Define the release root directory
6     TOP = ../../..
7
8     # Define the Tornado install directory and host type
9     WIND_BASE = c:/Tornado
10     WIND_HOST_TYPE = x86-win32
11
12     # define the base location of the standard makefile
13     MAKE_TOP = $(TOP)\Tornado\stdMakefiles
14
15     # TORNADO Makefile strategy-
16     # perform make with the -C <dir> for each valid target
17     # Each target subdir will select correct Make include environment
18     # target names hardcoded for now
19
20     default:: M30 X486
21
22     M30 :
23     mkdir M30
24     X486 :
25     mkdir X486
26
27     default::
28     make -C ./M30 -f $(MAKE_TOP)/Makefile user_target CUR=$(CUR) CPU=MC68060
29     make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
30
Powered by ViewVC 1.1.30
