/[TIS-4000 Rel T60]/Tornado/dbEmulator/Makefile.config
Contents of /Tornado/dbEmulator/Makefile.config
Revision 1.1 - (show annotations)
Mon Aug 23 18:43:17 1999 UTC (24 years, 6 months ago) by tis4000
Branch point for: HIA
1 #$Id: Makefile.config,v 1.1.1.1 1999/08/23 13:34:38 tis4000 Exp $
2
3 #
4 # Makefile.config
5 #
6 # this file contains specific configuration for a given directory '.../Vx/xxx'
7 # by defining the working directory name, any special include search path
8 # directories, the source file list (used for make 'depend'), and the object
9 # module list (used by default user target).
10 #
11
12
13 #
14 # extra switches for each machine flavor
15 #
16
17 M00INX = -I$(STDH)/sys -I$(STDH)/types -I$(STDH)/net -I$(STDH)/netinet -I$(TISH)/rec -I$(CFG)/../all
18 M00CCX = -DvxWorks -DV5_vxWorks
19 M00OPT = -g
20
21 M20INX = -I$(STDH)/sys -I$(STDH)/types -I$(STDH)/net -I$(STDH)/netinet -I$(TISH)/rec -I$(CFG)/../all
22 M20CCX = -DvxWorks -DV5_vxWorks
23 M20OPT = -g
24
25 M30INX = -I$(STDH)/sys -I$(STDH)/types -I$(STDH)/net -I$(STDH)/netinet -I$(TISH)/rec -I$(CFG)/../all
26 M30CCX = -DvxWorks -DV5_vxWorks
27 M30OPT = -g
28
29 X486INX = -I$(STDH)/sys -I$(STDH)/types -I$(STDH)/net -I$(STDH)/netinet -I$(TISH)/rec -I$(CFG)/../all
30 X486CCX = -DvxWorks -DV5_vxWorks
31 X486OPT = -g
32
33 #
34 # Define the source list for dbEmulator
35 #
36
37 SRCS =\
38 $(SRC)/dbEmulator.c \
39 $(SRC)/dbe2.c \
40 # ---
41
42 #
43 # Define the object list for dbEmulator
44 #
45
46 OBJS =\
47 dbEmulator.o \
48 dbe2.o \
49 # std.sdr \
50 # ---
51
52 PRIV_OBJS =\
53 priv_dbEmulator.o \
54 dbe2.o \
55 # std.sdr \
56 # ---
57
58 #
59 # END of Makefile.config
60 #
Powered by ViewVC 1.1.30
