/[TIS-4000 Rel T60]/Tornado/dbEmulator/Makefile.target
Contents of /Tornado/dbEmulator/Makefile.target
Branch: HIA
CVS Tags: T60
initial version
1 #$Id: Makefile.target,v 1.1.1.1 1999/08/23 13:34:38 tis4000 Exp $
2
3 #
4 # Makefile.target
5 #
6 # this file defines the default target and its components
7 # for the current build directory; there must be a target
8 # named 'user_target' (see Makefile.defaults) somewhere at
9 # the head of the chain, otherwise there aren't really any
10 # constraints ...
11 #
12
13 user_target: priv_dbEmulator dbEmulator
14
15 #
16 # Define targets for the dbEmulator
17 #
18
19 dbEmulator: $(OBJS)
20 @ echo "linking dbEmulator for $(DST)"
21 @ $(RM) $@
22 @ $(LD) -r $(OBJS) -o $@
23
24 priv_dbEmulator: $(PRIV_OBJS)
25 @ echo "linking priv_dbEmulator for $(DST)"
26 @ $(RM) $@
27 @ $(LD) -r $(PRIV_OBJS) -o $@
28
29 # note: by making the special version dependent on the
30 # standard, we inherit the dependencies.
31 priv_dbEmulator.o: dbEmulator.o
32 @ $(RM) priv_dbEmulator.o
33 $(CC) -DvxWorks -DV5_vxWorks -c $(CFLAGS) -DPRIV_AUDIT -o $@ $(SRC)/dbEmulator.c
34
35 std.sdr : $(SHR)/epicsH/rec/default.dctsdr
36 @ echo "creating linkable SDR ..."
37 @ $(VX_HSP_BASE)/bin/$(VX_HOST_TYPE)/binToAsm $? > tmp.s
38 @ $(GPATH)/cc$(TARG) -c tmp.s -o $@
39 @ $(RM) tmp.s
40
41 #
42 # END of Makefile.target
43 #
44 # Dependency list for .o files - automatically generated!!
45 # reference ./Makefile & ../Makefile.defaults
46 #
47
Powered by ViewVC 1.1.30
