/[TIS-4000 Rel T60]/Tornado/dbEmulator/Makefile.target
Contents of /Tornado/dbEmulator/Makefile.target
Revision 1.2 - (show annotations)
Fri Sep 17 11:20:47 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline
remove Id line - irani
1 #
2 # Makefile.target
3 #
4 # this file defines the default target and its components
5 # for the current build directory; there must be a target
6 # named 'user_target' (see Makefile.defaults) somewhere at
7 # the head of the chain, otherwise there aren't really any
8 # constraints ...
9 #
10
11 user_target: priv_dbEmulator dbEmulator
12
13 #
14 # Define targets for the dbEmulator
15 #
16
17 dbEmulator: $(OBJS)
18 @ echo "linking dbEmulator for $(DST)"
19 @ $(RM) $@
20 @ $(LD) -r $(OBJS) -o $@
21
22 priv_dbEmulator: $(PRIV_OBJS)
23 @ echo "linking priv_dbEmulator for $(DST)"
24 @ $(RM) $@
25 @ $(LD) -r $(PRIV_OBJS) -o $@
26
27 # note: by making the special version dependent on the
28 # standard, we inherit the dependencies.
29 priv_dbEmulator.o: dbEmulator.o
30 @ $(RM) priv_dbEmulator.o
31 $(CC) -DvxWorks -DV5_vxWorks -c $(CFLAGS) -DPRIV_AUDIT -o $@ $(SRC)/dbEmulator.c
32
33 std.sdr : $(SHR)/epicsH/rec/default.dctsdr
34 @ echo "creating linkable SDR ..."
35 @ $(VX_HSP_BASE)/bin/$(VX_HOST_TYPE)/binToAsm $? > tmp.s
36 @ $(GPATH)/cc$(TARG) -c tmp.s -o $@
37 @ $(RM) tmp.s
38
39 #
40 # END of Makefile.target
41 #
42 # Dependency list for .o files - automatically generated!!
43 # reference ./Makefile & ../Makefile.defaults
44 #
45
Powered by ViewVC 1.1.30
