/[TIS-4000 Rel T60]/Tornado/dbEmulator/Makefile.target
Log of /Tornado/dbEmulator/Makefile.target
Fri Dec 10 14:46:29 1999 UTC (23 years, 11 months ago) by tis4000
Changes since 1.2: +4 -1 lines
Placed special targets that are X486 or privilege dependent in the target defined
by the CPU = I80486.
Steel
Fri Sep 17 11:20:47 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: CAISO, t55baseline
remove Id line - irani
Mon Aug 23 18:43:18 1999 UTC (24 years, 3 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
