/[TIS-4000 Rel T60]/Tornado/devCom/Makefile.config
Contents of /Tornado/devCom/Makefile.config
Revision 1.1 - (show annotations)
Branch point for: HIA
1 #$Id: Makefile.config,v 1.1.1.1 1999/08/23 13:34:38 tis4000 Exp $
2
3 #
4 # Makefile.config
5 #
6 # this file contains specific configuration for a given directory '.../Vx/xxx'
7 # by defining the working directory name, any special include search path
8 # directories, the source file list (used for make 'depend'), and the object
9 # module list (used by default user target).
10 #
11
12 #
13 # extra switches for each machine flavor
14 #
15
16 M00INX = -I$(TISH)/rec
17 M00CCX = -DvxWorks -DV5_vxWorks
18 M00OPT = -g
19
20 M20INX = -I$(TISH)/rec
21 M20CCX = -DvxWorks -DV5_vxWorks
22 M20OPT = -g
23
24 M30INX = -I$(TISH)/rec
25 M30CCX = -DvxWorks -DV5_vxWorks
26 M30OPT = -g
27
28 X486INX = -I$(TISH)/rec
29 X486CCX = -DvxWorks -DV5_vxWorks
30 X486OPT = -g
31
32 #
33 # Define the source list for devCom.o
34 #
35
36 SRCS =\
37 $(SRC)/devRes.c \
38 $(SRC)/devSoft.c \
39 $(SRC)/devSoftRaw.c \
40 $(SRC)/devTestAsyn.c \
41 # ---
42
43 #
44 # Define the object list for devCom.o
45 #
46
47 OBJS =\
48 devRes.o \
49 devSoft.o \
50 devSoftRaw.o \
51 devTestAsyn.o \
52 # ---
53
54 #
55 # END of Makefile.config
56 #
Powered by ViewVC 1.1.30
