/[TIS-4000 Rel T60]/Tornado/devCom/Makefile
Annotation of /Tornado/devCom/Makefile
Revision 1.2 - (hide annotations)
Fri Sep 17 13:17:44 1999 UTC (24 years, 5 months ago) by tis4000
CVS Tags: CAISO, t55baseline, Duluth_baseline, LMC_baseline, HEAD
Remove Id line - irani
1 tis4000 1.1 # Define the local target base directory
2     CUR = devCom
3
4     # Define the release root directory
5     TOP = ../../..
6
7     # Define the Tornado install directory and host type
8     WIND_BASE = c:/Tornado
9     WIND_HOST_TYPE = x86-win32
10
11     # define the base location of the standard makefile
12     MAKE_TOP = $(TOP)\Tornado\stdMakefiles
13
14     # TORNADO Makefile strategy-
15     # perform make with the -C <dir> for each valid target
16     # Each target subdir will select correct Make include environment
17     # target names hardcoded for now
18
19     default:: M30 X486
20
21     M30 :
22     mkdir M30
23     X486 :
24     mkdir X486
25
26     default::
27     make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68060
28     make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
29
Powered by ViewVC 1.1.30
