/[TIS-4000 Rel T60]/Tornado/drvCom/Makefile.config
Contents of /Tornado/drvCom/Makefile.config
Branch: HIA
CVS Tags: T60
initial version
1 #$Id: Makefile.config,v 1.1.1.1 1999/08/23 13:34:38 tis4000 Exp $
2
3 #
4 # Makefile.config
5 #
6 # this file contains specific configuration for a given directory '.../Vx/xxx'
7 # by defining the working directory name, any special include search path
8 # directories, the source file list (used for make 'depend'), and the object
9 # module list (used by default user target).
10 #
11
12
13 #
14 # extra switches for each machine flavor
15 #
16
17 M00INX = -I$(CFG) -I$(CFG)/../all -I$(DRVH)/drv/tis
18 M00CCX = -DvxWorks -DV5_vxWorks -DTARGET_MSOL
19 M00OPT = -g
20
21 M20INX = -I$(CFG) -I$(CFG)/../all -I$(STDH)/drv/tis
22 M20CCX = -DvxWorks -DV5_vxWorks
23 M20OPT = -g
24
25 M30INX = -I$(CFG) -I$(CFG)/../all -I$(STDH)/drv/tis
26 M30CCX = -DvxWorks -DV5_vxWorks
27 M30OPT = -g
28
29 X486INX = -I$(CFG) -I$(CFG)/../all -I$(STDH)/drv/tis
30 X486CCX = -DvxWorks -DV5_vxWorks
31 X486OPT = -g
32
33 #
34 # Define the source list for drvCom.o
35 #
36
37 SRCS =\
38 $(SRC)/gentimer.c \
39 $(SRC)/masks.c \
40 $(SRC)/iocsiodvr_bridge.c \
41 $(SRC)/drvcommon.c \
42 $(SRC)/cpuLoad.c \
43 $(SRC)/redundTask.c \
44 $(SRC)/serialTask.c \
45 $(SRC)/tomato.c \
46 $(SRC)/resGroupTask.c \
47 $(SRC)/serialFile.c \
48 # ---
49
50 #
51 # Define the object list for drvCom.o
52 #
53
54 OBJS =\
55 gentimer.o \
56 masks.o \
57 iocsiodvr_bridge.o \
58 drvcommon.o \
59 cpuLoad.o \
60 redundTask.o \
61 serialTask.o \
62 tomato.o \
63 resGroupTask.o \
64 serialFile.o \
65 # ---
66
67 #
68 # END of Makefile.config
69 #
Powered by ViewVC 1.1.30
