/[TIS-4000 Rel T60]/Tornado/libCom/Makefile.config
Contents of /Tornado/libCom/Makefile.config
Branch: HIA
CVS Tags: T60
initial version
1 #$Id: Makefile.config,v 1.1.1.1 1999/08/23 13:34:38 tis4000 Exp $
2
3 #
4 # Makefile.config
5 #
6 # this file contains specific configuration for a given directory '.../Vx/xxx'
7 # by defining the working directory name, any special include search path
8 # directories, the source file list (used for make 'depend'), and the object
9 # module list (used by default user target).
10 #
11
12
13 #
14 # extra switches for each machine flavor
15 #
16
17 M00INX =
18 M00CCX = -DvxWorks -DV5_vxWorks
19 M00OPT = -g
20
21 M20INX =
22 M20CCX = -DvxWorks -DV5_vxWorks
23 M20OPT =
24
25 M30INX =
26 M30CCX = -DvxWorks -DV5_vxWorks
27 M30OPT =
28
29 X486INX =
30 X486CCX = -DvxWorks -DV5_vxWorks
31 X486OPT =
32
33 #
34 # Define the source list for libCom.o
35 #
36
37 SRCS =\
38 $(SRC)/calcPerform.c \
39 $(SRC)/envSubr.c \
40 $(SRC)/errMessage.c \
41 $(SRC)/errPrint.c \
42 $(SRC)/errSymFind.c \
43 $(SRC)/genSubr.c \
44 $(SRC)/genTaskSubr.c \
45 $(SRC)/nextFieldSubr.c \
46 $(SRC)/okToUse.c \
47 $(SRC)/postfix.c \
48 $(SRC)/pvd.c \
49 $(SRC)/tsSubr.c \
50 $(SRC)/sdrLoad.c \
51 # $(SRC)/cmdSubr.c \
52 # $(SRC)/cvtNumbers.c \
53 # $(SRC)/ezsSockSubr.c \
54 # $(SRC)/helpSubr.c \
55 # $(SRC)/sydSubr.c \
56 # $(SRC)/sydSubrCA.c \
57 # $(SRC)/sydSubrCF.c \
58 # $(SRC)/sydSubrSSF.c \
59 # ---
60
61 #
62 # Define the object list for libCom.o
63 #
64
65 # routines required in iocCore
66 OBJS0 =\
67 calcPerform.o \
68 envSubr.o \
69 errMessage.o \
70 errPrint.o \
71 errSymFind.o \
72 genSubr.o \
73 genTaskSubr.o \
74 nextFieldSubr.o \
75 okToUse.o \
76 postfix.o \
77 pvd.o \
78 tsSubr.o \
79 sdrLoad.o \
80 # ---
81
82 # low level routines for certain tools, e.g. cau
83 #OBJS1 =\
84 # cmdSubr.o \
85 # cvtNumbers.o \
86 # ezsSockSubr.o \
87 # helpSubr.o \
88 # ---
89
90 # high level routines for various tools & applications
91 #OBJS2 =\
92 # sydSubr.o \
93 # sydSubrCA.o \
94 # sydSubrCF.o \
95 # sydSubrSSF.o \
96 # ---
97
98 #
99 # END of Makefile.config
100 #
Powered by ViewVC 1.1.30
