/[TIS-4000 Rel T60]/Tornado/rec/Makefile
Diff of /Tornado/rec/Makefile
Parent Directory Parent Directory | Revision Log Revision Log | View Revision Graph Revision Graph | View Patch Patch
revision 1.1 by tis4000, Mon Aug 23 18:43:19 1999 UTC revision 1.2 by tis4000, Fri Sep 17 13:17:45 1999 UTC
# Line 1  Line 1
 #$Id$
1  # Define the local target base directory  # Define the local target base directory
2  CUR = rec  CUR = rec
3
# Line 25  M30 : Line 23  M30 :
23  X486 :  X486 :
24          mkdir X486          mkdir X486
25
26  default::  default::
27          make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68060          make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68060
28          make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486          make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
29
Legend:
Removed from v.1.1
changed lines
  Added in v.1.2
Powered by ViewVC 1.1.30
