/[TIS-4000 Rel T60]/Tornado/redund/Makefile.target
Contents of /Tornado/redund/Makefile.target
Revision 1.5 - (show annotations)
Fri Aug 11 14:10:52 2000 UTC (23 years, 4 months ago) by tis4000
CVS Tags: Duluth_baseline, LMC_baseline, HEAD
added emergency.o target - Steel
1 #
2 # Makefile.target
3 #
4 # this file defines the default target and its components
5 # for the current build directory; there must be a target
6 # named 'user_target' (see Makefile.defaults) somewhere at
7 # the head of the chain, otherwise there aren't really any
8 # constraints ...
9 #
10 ifeq ($(CPU),I80486)
11 user_target: dbServer priv_dbServer scriptTask.o emergency.o
12 else
13 user_target: dbServer scriptTask.o emergency.o
14 endif
15
16 # getsocklinger.o
17
18 #
19 # Define targets for the dbServer
20 #
21
22 dbServer: $(OBJS)
23 @ echo "linking dbServer for $(DST)"
24 @ $(RM) $@
25 @ $(LD) -r $(OBJS) -o $@
26
27 #
28 # Define targets for the priv_dbServer
29 #
30
31 priv_dbServer: $(PRIV_OBJS)
32 @ echo "linking priv_dbServer for $(DST)"
33 @ $(RM) $@
34 @ $(LD) -r $(PRIV_OBJS) -o $@
35
36 # note: by making the special version dependent on the
37 # standard, we inherit the dependencies.
38 priv_dbserver.o: dbserver.o
39 @ $(RM) priv_dbserver.o
40 $(CC) -DvxWorks -DV5_vxWorks -c $(CFLAGS) -DPRIV_AUDIT -o $@ $(SRC)/dbserver.c
41
42 # getsocklinger.o: ..\..\../share/src/redund/getsocklinger.c
43
44 #
45 # END of Makefile.target
46 #
47 # Dependency list for .o files - automatically generated!!
48 # reference ./Makefile & ../Makefile.defaults
49 #
50
Powered by ViewVC 1.1.30
