/[TIS-4000 Rel T60]/Tornado/rsrv/Makefile.target |
Parent Directory
Revision Log
Revision Graph
Sticky Tag: |
Placed special targets that are X486 or privilege dependent in the target defined by the CPU = I80486. Steel
Remove Id line - irani
initial version
ViewVC Help | |
Powered by ViewVC 1.1.30 |
