/[TIS-4000 Rel T60]/Tornado/servers/Makefile.target
Log of /Tornado/servers/Makefile.target
Fri Dec 10 15:58:24 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.1: +4 -12 lines
This file was the Makefile.target for rec, replaced with proper file - Steel
Wed Nov 10 19:13:57 1999 UTC (24 years, 3 months ago) by tis4000
CVS Tags: SPR393
SPR 393
Included iocTrend target for Tornado. - Steel
Powered by ViewVC 1.1.30
