/[TIS-4000 Rel T60]/Tornado/sstools/MAKEFILE
Log of /Tornado/sstools/MAKEFILE
Wed Dec 15 16:43:01 1999 UTC (24 years, 2 months ago) by tis4000
removed ID line - Steel
Tue Dec 14 15:52:09 1999 UTC (24 years, 2 months ago) by tis4000
disable 68kk build - Steel
Branch point for: HIA
Diff to selected 1.2
Powered by ViewVC 1.1.30
