/[TIS-4000 Rel T60]/Tornado/sstools/MAKEFILE
Annotation of /Tornado/sstools/MAKEFILE
Revision 1.3 - (hide annotations)
Wed Dec 15 16:43:01 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: Duluth_baseline, LMC_baseline, HEAD
removed ID line - Steel
1 tis4000 1.1 # Define the local target base directory
2     CUR = sstools
3
4     # Define the release root directory
5     TOP = ../../..
6
7     # define the base location of the standard makefile
8     MAKE_TOP = $(TOP)\Tornado\stdMakefiles
9
10     # TORNADO Makefile strategy-
11     # perform make with the -C <dir> for each valid target
12     # Each target subdir will select correct Make include environment
13     # target names hardcoded for now
14
15     default:: M30 X486
16
17     M30 :
18     mkdir M30
19     X486 :
20     mkdir X486
21
22     default::
23 tis4000 1.2 # make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68060
24 tis4000 1.1 make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
25
Powered by ViewVC 1.1.30
