/[TIS-4000 Rel T60]/Tornado/sstools/Makefile.config
Contents of /Tornado/sstools/Makefile.config
Branch: HIA
CVS Tags: T60
initial version
1 #$Id: Makefile.config,v 1.1.1.1 1999/08/23 13:34:41 tis4000 Exp $
2
3 #
4 # Makefile.config
5 #
6 # this file contains specific configuration for a given directory '.../Vx/xxx'
7 # by defining the working directory name, any special include search path
8 # directories, the source file list (used for make 'depend'), and the object
9 # module list (used by default user target).
10 #
11
12 #
13 # extra switches for each machine flavor
14 #
15
16 M00INX =
17 M00CCX = -DvxWorks -DV5_vxWorks
18 M00OPT = -g
19
20 M20INX =
21 M20CCX = -DvxWorks -DV5_vxWorks
22 M20OPT = -g
23
24 M30INX =
25 M30CCX = -DvxWorks -DV5_vxWorks
26 M30OPT = -g
27
28 X486INX =
29 X486CCX = -DvxWorks -DV5_vxWorks
30 X486OPT = -g
31
32 #
33 # individual module compiler flag requirements
34 # for particularly persnickety objects
35 #
36
37 #
38 # Define the source list for CalISO.o
39 #
40
41 SRCS =\
42 $(SRC)\sslib.c \
43 $(SRC)\names.c \
44 $(SRC)\compare.c \
45 $(SRC)\queues.c \
46 $(SRC)\netdata.c \
47 $(SRC)\timers.c \
48 $(SRC)\trace.c \
49 $(SRC)\audit.c \
50 $(SRC)\auditx.c \
51 $(SRC)\level1.c \
52 $(SRC)\l1_tcp.c \
53 $(SRC)\l1_winx.c \
54 $(SRC)\l1_ssl.c \
55 $(SRC)\l1_sslx.c \
56 $(SRC)\l1_digi.c \
57 $(SRC)\l1_unix.c \
58 $(SRC)\l1_8250x.c \
59 $(SRC)\tcpvxw.c \
60 $(SRC)\libvxw.c \
61 # ---
62
63 #
64 # Define the object list for CalISO.o
65 #
66
67 OBJS =\
68 sslib.o \
69 names.o \
70 compare.o \
71 queues.o \
72 netdata.o \
73 timers.o \
74 trace.o \
75 audit.o \
76 level1.o \
77 l1_tcp.o \
78 l1_winx.o \
79 l1_ssl.o \
80 l1_digi.o \
81 l1_unix.o \
82 l1_8250x.o \
83 tcpvxw.o \
84 libvxw.o \
85 # ---
86
87 OBJSX =\
88 sslib.o \
89 names.o \
90 compare.o \
91 queues.o \
92 netdata.o \
93 timers.o \
94 trace.o \
95 auditx.o \
96 level1.o \
97 l1_tcp.o \
98 l1_winx.o \
99 l1_sslx.o \
100 l1_digi.o \
101 l1_unix.o \
102 l1_8250x.o \
103 tcpvxw.o \
104 libvxw.o \
105 # ---
106
107 # END of Makefile.config
108 #
Powered by ViewVC 1.1.30
