/[TIS-4000 Rel T60]/Tornado/stdMakefiles/Makefile.project
Contents of /Tornado/stdMakefiles/Makefile.project
Branch: HIA
CVS Tags: T60
initial version
1 #$Id: Makefile.project,v 1.1.1.1 1999/08/23 13:34:41 tis4000 Exp $
2
3 # Define the local target base directory
4 CUR = PUT_YOUR_DIRECTORY_HERE
5
6 # Define the release root directory
7 TOP = ../../..
8
9 # define the base location of the standard makefile
10 MAKE_TOP = $(TOP)\Tornado\stdMakefiles
11
12 # TORNADO Makefile strategy-
13 # perform make with the -C <dir> for each valid target
14 # Each target subdir will select correct Make include environment
15 # target names hardcoded for now
16
17 default:
18 make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68060
19 make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
20
Powered by ViewVC 1.1.30
