/[TIS-4000 Rel T60]/Tornado/stdMakefiles/getverdefs.bat
Log of /Tornado/stdMakefiles/getverdefs.bat
Tue Dec 7 20:59:21 1999 UTC (24 years ago) by tis4000
Batch file that uses awk to format release, project, and build date definitions to be put into buildVersion.h - Bekkerman
Powered by ViewVC 1.1.30
