/[TIS-4000 Rel T60]/Tornado/stdMakefiles/vrsscript.sed
Log of /Tornado/stdMakefiles/vrsscript.sed
Tue Dec 7 21:00:51 1999 UTC (24 years, 2 months ago) by tis4000
Sed script that creates release and project definitions to be put into buildVersion.h - Bekkerman
Powered by ViewVC 1.1.30
