/[TIS-4000 Rel T60]/Tornado2/CalISO/Makefile
Contents of /Tornado2/CalISO/Makefile
Fri Apr 21 17:36:10 2000 UTC (22 years, 5 months ago) by tis4000
Branch: HIA, MAIN
Setup Initial Baseline
1
2 # Define the local target base directory
3 CUR = CalISO
4
5 # Define the release root directory
6 TOP = ../../..
7
8 # define the base location of the standard makefile
9 MAKE_TOP = $(TOP)\Tornado2\stdMakefiles
10
11 # TORNADO Makefile strategy-
12 # perform make with the -C <dir> for each valid target
13 # Each target subdir will select correct Make include environment
14 # target names hardcoded for now
15
16 default:: M30 X486
17
18 M30 :
19 mkdir M30
20 X486 :
21 mkdir X486
22
23 X486_O:
24 make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
25
26
Powered by ViewVC 1.1.28
