/[TIS-4000 Rel T60]/Tornado2/Dnp/MAKEFILE
Contents of /Tornado2/Dnp/MAKEFILE
Fri Apr 21 17:36:14 2000 UTC (23 years, 1 month ago) by tis4000
Branch: HIA, MAIN
Error occurred while calculating annotation data.
Setup Initial Baseline
1 #$Id: MAKEFILE,v 1.1.1.1 1999/08/23 13:34:38 tis4000 Exp $
2
3 # Define the local target base directory
4 CUR = Dnp
5
6 # Define the release root directory
7 TOP = ../../..
8
9 # define the base location of the standard makefile
10 MAKE_TOP = $(TOP)\Tornado2\stdMakefiles
11
12 # TORNADO Makefile strategy-
13 # perform make with the -C <dir> for each valid target
14 # Each target subdir will select correct Make include environment
15 # target names hardcoded for now
16
17 default:: M30 X486
18
19 M30 :
20 mkdir M30
21 X486 :
22 mkdir X486
23
24 M30_O:
25 make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68040
26
27 X486_O:
28 make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
29
Powered by ViewVC 1.1.28
