/[TIS-4000 Rel T60]/Tornado2/Dnp/Makefile.config
Log of /Tornado2/Dnp/Makefile.config
Revision 1.3 - (view) (annotate) - [selected]
Fri Aug 11 12:42:37 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.2: +14 -4 lines
Changed file to allow DNP Master/Slave coexistence. - Johnson
Thu Jun 15 20:18:40 2000 UTC (23 years, 3 months ago) by tis4000
Removed references to SHADOW.C. - Johnson
Fri Apr 21 17:36:14 2000 UTC (23 years, 5 months ago) by tis4000
Branch point for: HIA
Diff to selected 1.3
Powered by ViewVC 1.1.30
