/[TIS-4000 Rel T60]/Tornado2/Netpac/Makefile
Contents of /Tornado2/Netpac/Makefile
Revision 1.1 - (show annotations)
Fri Apr 21 17:36:23 2000 UTC (23 years, 1 month ago) by tis4000
Branch point for: HIA, MAIN
1 #$Id: Makefile,v 1.1.1.1 1999/08/23 13:34:39 tis4000 Exp $
2
3 #
4 # this Makefile is basically a stub to ensure the auto-regeneration
5 # of the target-specific makefiles and their subsequent execution; it
6 # checks the dependencies of the component Makefile.* files just in
7 # case something changes ...
8 #
9
10 include Makefile.config
11
12 #
13 # tl is a small 'C' program to get the tail of the current
14 # directory and stuff it into CUR
15 #
16
17 CUR:sh = ../makeutils/tl `eval pwd`
18
19 #
20 # this is a 'null' target to force the execution of our Makefiles
21 #
22
23 default:: M30 X486
24
25 M30 :
26 mkdir M30
27 X486 :
28 mkdir X486
29
30 M30_O:
31 make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68060
32
33 X486_O:
34 make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
35
36 default::
37 @ for sd in * ; do \
38 if test -d $$sd ; then \
39 ( cd $$sd ; \
40 echo "" ; \
41 echo "checking $(CUR)/$$sd Makefile ..." ; \
42 if test $$sd = M00 ; then set 68000 soft-float msol 68k 68K MC68000; \
43 elif test $$sd = M30 ; then set 68030 68881 mv147 68k 68K MC68030; \
44 elif test $$sd = X486 ; then set 486 "" pc386 386 386 I80486; \
45 else \
46 if test $$sd != CVS ; then echo "$$sd is not a target directory" ; fi ; \
47 continue ; \
48 fi ; \
49 make -f ../../Makefile.defaults CPU=$$1 FLT=$$2 BSP=$$3 DST=$$sd CUR=$(CUR) TARG=$$4 GCC_BASE=$$5 CPU_FAM=$$6 Makefile.$$sd ; \
50 echo "building $(CUR)/$$sd targets ..." ; \
51 make -f Makefile.$$sd \
52 ) ; \
53 fi ; \
54 done
55
56 #
57 # utility targets
58 #
59
60 clean:
61 @ for sd in * ; do \
62 if test -d $$sd ; then \
63 if test $$sd = M00 -o $$sd = M30 -o $$sd = X486; then \
64 echo "removing "`eval pwd`"/$$sd targets ..." ; $(RM) $$sd/* ; \
65 else \
66 if test $$sd != CVS ; then echo "$$sd is not a target directory" ; fi ; \
67 continue ; \
68 fi ; \
69 fi ; \
70 done
Powered by ViewVC 1.1.28
