/[TIS-4000 Rel T60]/Tornado2/Quad4/Makefile.config
Annotation of /Tornado2/Quad4/Makefile.config
Revision 1.1.1.1 - (hide annotations) (vendor branch)
Fri Apr 21 17:36:25 2000 UTC (22 years, 11 months ago) by tis4000
Branch: HIA, MAIN
Setup Initial Baseline
1 tis4000 1.1 #
2     # Makefile.config
3     # !! special 'driver' version = Makefile.drvcnfg
4     #
5     # this file contains specific configuration for a given directory '.../Vx/xxx'
6     # by defining the working directory name, any special include search path
7     # directories, the source file list (used for make 'depend'), and the object
8     # module list (used by default user target).
9     #
10
11     #
12     # extra switches for each machine flavor
13     #
14
15     M30INX =
16
17     X486INX =
18
19     #
20     # Define the source list for $(CUR).o
21     #
22
23     SRCS =\
24     $(SRC)\dev$(CUR).c \
25     $(SRC)\drv$(CUR).c \
26     $(SRC)\vxquad4.c \
27     $(SRC)\q4task.c \
28     $(SRC)\meter.c \
29     $(SRC)\mv90.c \
30     # ---
31
32     #
33     # Define the object list for $(CUR).o
34     #
35
36     OBJS =\
37     dev$(CUR).o \
38     drv$(CUR).o \
39     vxquad4.o \
40     q4task.o \
41     meter.o \
42     mv90.o \
43     # ---
44
45     #
46     # END of Makefile.config
47     #
Powered by ViewVC 1.1.28
