/[TIS-4000 Rel T60]/Tornado2/Quad4/Makefile.config
Contents of /Tornado2/Quad4/Makefile.config
Fri Apr 21 17:36:25 2000 UTC (22 years, 9 months ago) by tis4000
Branch: HIA, MAIN
Error occurred while calculating annotation data.
Setup Initial Baseline
1 #
2 # Makefile.config
3 # !! special 'driver' version = Makefile.drvcnfg
4 #
5 # this file contains specific configuration for a given directory '.../Vx/xxx'
6 # by defining the working directory name, any special include search path
7 # directories, the source file list (used for make 'depend'), and the object
8 # module list (used by default user target).
9 #
10
11 #
12 # extra switches for each machine flavor
13 #
14
15 M30INX =
16
17 X486INX =
18
19 #
20 # Define the source list for $(CUR).o
21 #
22
23 SRCS =\
24 $(SRC)\dev$(CUR).c \
25 $(SRC)\drv$(CUR).c \
26 $(SRC)\vxquad4.c \
27 $(SRC)\q4task.c \
28 $(SRC)\meter.c \
29 $(SRC)\mv90.c \
30 # ---
31
32 #
33 # Define the object list for $(CUR).o
34 #
35
36 OBJS =\
37 dev$(CUR).o \
38 drv$(CUR).o \
39 vxquad4.o \
40 q4task.o \
41 meter.o \
42 mv90.o \
43 # ---
44
45 #
46 # END of Makefile.config
47 #
Powered by ViewVC 1.1.28
