/[TIS-4000 Rel T60]/Tornado2/Rtp/Makefile.config
Contents of /Tornado2/Rtp/Makefile.config
Fri Apr 21 17:36:26 2000 UTC (22 years, 9 months ago) by tis4000
Branch: HIA, MAIN
Setup Initial Baseline
1 #
2 # Makefile.config
3 # !! special 'driver' version = Makefile.drvcnfg
4 #
5 # this file contains specific configuration for a given directory '.../Vx/xxx'
6 # by defining the working directory name, any special include search path
7 # directories, the source file list (used for make 'depend'), and the object
8 # module list (used by default user target).
9 #
10
11 #
12 # extra switches for each machine flavor
13 #
14
15 M30INX =
16
17 X486INX =
18
19 #
20 # Define the source list for $(CUR).o
21 #
22
23 SRCS =\
24 $(SRC)/dev$(CUR).c \
25 $(SRC)/drv$(CUR).c \
26 # ---
27
28 #
29 # Define the object list for $(CUR).o
30 #
31
32 OBJS =\
33 dev$(CUR).o \
34 drv$(CUR).o \
35 # ---
36
37 #
38 # END of Makefile.config
39 #
Powered by ViewVC 1.1.28
